It is currently Sun Sep 06, 2026 5:33 am
 Post subject: Foam : Tech name ?
PostPosted: Wed May 26, 2021 8:00 am
Could anybody tell me the correct name for the foam for a HC14T ?
I need to repair a big crash and want to buy a piece of foam as the original one :D
The original is white and 5mm
 Post subject: Re: Foam : Tech name ?
PostPosted: Wed May 26, 2021 11:25 am
That old foam would not be available. Was sliced by Clarke Foam that is no longer in business. We most recently used 1/4" 4# PVC. Depending on the size of the area, you can fill with glass and disregard the foam.
PostPosted: Wed May 26, 2021 11:04 pm
Thx for answer !!!!
It is a "big" hole ( +- 40x40 cm ), so I prefer place foam there.
PostPosted: Fri Feb 27, 2026 1:48 pm
I could be dead wrong on this, but I believe the purpose of the foam was to provide shape and back the fiberglass and resin. You could probably use any foam in a can from any marine supply once you get all the exterior ground back. Then shape the foam and glass it.
Here's a link to a short video explanation. (link opens YouTube — right-click to open in new tab)
