It is currently Sat Aug 08, 2026 7:29 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Oct 16, 2013 9:42 am
The stepper bracket does fit the T2 / H16 mast section. The fit is adequate for use of the stepper III on the T2 I believe. At most an additional pad or slight bend in the forward part of the bracket would make a perfect fit I think. Since the pole is long and attachments are adjustable. Should be no problem. If we get a chance to assemble one and test... we'll let you know. At least the T2 will be simpler as it has trapeze wire for use as anti-sway.
PostPosted: Thu Oct 17, 2013 1:55 pm
Ah, bummer on the glued-mast requirement .... will have to figure how to store a 26ft mast (tricky!) with boat on trailer (OK) in a Wave-sufficient 18 ft garage, between summer-sailing events and over the winter break!
PostPosted: Sat Oct 19, 2013 12:34 pm
Thanks for the details.
I have one other request that may seem at bit odd, but may be a good sales advertisement too!
It is difficult to get any size perspective from online photos and videos unless there is some common reference in the picture too. Could you post a picture of the T2 sitting on the ground/lawn along side a Wave, maybe? Or some other point of reference? Please.
PostPosted: Tue Oct 22, 2013 11:58 am
That would be a great idea ... maybe parked end-to-end on a lawn or beach would give good perspective.
PostPosted: Tue Oct 22, 2013 12:17 pm
Getaway and H16 are both 16'7" in length. T2 is 16'
---------------------------------- H16/Getaway 16'7"
-------------------------------- T2 16'
Yeah, everybody loves a smartass!!!!!! The T2 is just a tad shorter.
PostPosted: Tue Oct 22, 2013 8:45 pm
Thanks, can you give a graphic of the other two dimensions too...
