It is currently Mon Aug 03, 2026 5:47 am
PostPosted: Mon Oct 17, 2005 2:07 am
I just sail my H18 back home and found there are something inside the starboard hull, I can touch something from the drain hole at the back and it seems like a plastic bag.
I don't know what it is, i suspect it is the foam inside. Do i need to take it out? As I found the starboard hull is much heavier than the port hull.
your advice is seeking, thanks.
be
Hobie 18 SX w/wings
#28
PostPosted: Mon Oct 17, 2005 5:09 am
It's the foam flotation and should not be removed. The plastic bag it's in is to keep it from being dissolved by the resin fumes during assembly.
PostPosted: Mon Oct 17, 2005 6:56 am
thanks ar :D
