It is currently Mon Aug 03, 2026 5:01 pm
 Post subject: Need a measure
PostPosted: Sun Oct 23, 2011 2:55 am
Hi there,
can someone tell me the height and the width of the daggerboard.
thank you
max
 Post subject: Re: Need a measure
PostPosted: Sun Oct 23, 2011 7:49 pm
Approximately 48" x 16" as best I can measure (it is an odd oval shape).
PostPosted: Mon Oct 24, 2011 12:30 am
ops mine is 43.7" X 16
too short but there are no damage signs on the bottom
PostPosted: Mon Oct 24, 2011 11:37 am
Someone else ?
just to have a double check...
PostPosted: Mon Oct 24, 2011 3:22 pm
I have four in the basement....as the previous poster suggested , they aren't easy to measure due to their elliptical nature.. So I stood mine up against an inside wall corner, with the leading edge flush to the square corner...I find that measuring from the floor to the highest point above the rope attachment hole I get 47 inches max....and I also find that my boards are 16 and 1/16 inches wide when measured from the wall to the trailing edge. I can get 48 inches if I measure a little diagonally, but I don't think that's a true measure of height....hope this info is helpful.
PostPosted: Mon Nov 14, 2011 2:34 pm
So, my board miss some centimeters.
I need to fix this...
I take a piece of marine board wood and cut the piece that is missing
this is the 2cm marine wood profile.
I have used sandpaper to shape the piece and then with epoxy and a special structural filler i glued them togheter
And then shaped by hand
next step i'll use some carbon fiber to join the old piece with the new one and paint with epoxy and graphite filler.
