It is currently Mon Aug 03, 2026 10:23 am
 Post subject: Soft spot question
PostPosted: Mon Jul 21, 2014 8:59 am
I have a soft spot on my deck. Can I use expanding foam and fiberglass over the holes to make them water right or does it have to be injected with epoxy?
 Post subject: Re: Soft spot question
PostPosted: Mon Jul 21, 2014 9:02 am
Lots of discussion on the subject.
Don't use expanding foam... use Epoxy and best for the task is GitRot.
FAQ: http://www.hobiecat.com/forums/viewtopic.php?f=18&t=1156
PostPosted: Mon Jul 21, 2014 11:47 am
Has to be injected with epoxy. You need something that will re-bond the fiberglass layers to the foam core. Injecting expanding foam will not achieve this, and the soft spot will remain soft and continue to grow. Where in the deck, and approximately how big?
Mike
'78 H18 (unnamed) sail #14921
'08 H16 sail #114312
'97 H21SC sail #238
