It is currently Sat Jun 20, 2026 8:22 am
 Post subject: shroud anchor pins
PostPosted: Sun Sep 28, 2008 6:55 am
In replacing my shroud anchor pins, I am having a hard time finding a socket that fits inside the bearing plate. Any suggestions for where to find a very thin socket?
H18 #4549 Catasaurus
PostPosted: Sun Sep 28, 2008 9:05 am
Good on ya for changing those suckers!
I stick a pair of vice Grips up in there. Grease the new ones up with Lanocote or some other grease/anti-seize so they don't gall.
Happy sailing!
Sail Revolution
Join us on our new FB Page!
PostPosted: Sun Sep 28, 2008 5:40 pm
Agreed, use a vice grip to hold the nut. Stick a screwdriver into the hole of the anchor bolt to tighten or use a pair of plyers.
PostPosted: Sun Sep 28, 2008 7:07 pm
srm wrote:
Agreed, use a vice grip to hold the nut. Stick a screwdriver into the hole of the anchor bolt to tighten or use a pair of plyers. sm
When tightening the new anchor pins, just snug is plenty tight enough.
Too tight and you are unnecessarily stressing the fiberglass.
If you leave them even a little bit loose, it stresses the bolt as the mast "walks" back and forth.
Stephen
If the grass is greener on the other side of the fence, maybe it is time to water your own lawn.
