It is currently Sat Jun 20, 2026 3:20 pm
PostPosted: Wed Dec 16, 2009 5:59 pm
I am thinking about getting a Cheata bracket and outboard for my 18' Magnum. Probably most of the time, I will be in the Chesapeake Bay which can get fairly strong winds and disruptive/high seas. (This is particularly true when you are caught out in a summer squall)[b][/b]
So my questions, for those of you who use this setup, are as follows: what horsepower engine do you use; what shaft length is best (I am concerned with the short shaft that it will be coming in and out of the water when the wave action heats up); what approximate speed do you get both without and with significant head wind?
Thanks In Advance!
Are there other questions I should have asked but was just too ignorant to ask them?
I would rather be sailing than talking about sailing!
PostPosted: Wed Dec 16, 2009 6:05 pm
Low horse power (1-2) and short shaft are recommended for Cheata brackets. They are not strong enough for more than that. You may be able to modify them to get more strength, but the above is there typical recommendation
PostPosted: Wed Dec 16, 2009 6:21 pm
Thanks Matt! Have a Great Holiday!
PostPosted: Fri Dec 18, 2009 6:52 pm
[color=#0000FF]So my questions, for those of you who use this setup, are as follows: what horsepower engine do you use; what shaft length is best (I am concerned with the short shaft that it will be coming in and out of the water when the wave action heats up); what approximate speed do you get both without and with significant head wind?[/color]
I have the Honda 2HP 4-stroke for my 21SE and it makes getting into and out of the busy boat ramp a pleasure. A couple of sailing days ago my wife and I flipped the boat on our last run into the beach. To make a long story short.....we went straight to the beach once we were up and going. We had drifted down the lake shore about 200yds or so. We lowered the mainsail and it took quite a few pulls on the motor to get it start as it was on its side for approximately 30 minutes. The winds were sideshore 15-25 and the waves were 3-5 feet. Once I got the motor to start I gave it gas and the boat did not want to move with that much side and head wind. I thought I broke a propeller pin....The whole reason for writing this is the small lightweight engine is the best for weight to power, but has a lot of trouble pushing during the high wind days. Sail the boat when its windy and use the motor to assist when there is lighter winds. The next time I will sail into the dock if I have the stronger winds. This is similar to a fishing boat and the kicker motor can't push them either when the winds are up.
