It is currently Mon Aug 03, 2026 6:58 am
 Post subject: hobie 18SX adjustment
PostPosted: Tue Sep 13, 2005 7:58 am
for what use is the luff line going all the way up the sail far the mylar dacron laminate sail of a hobie 18sx we can atck it at diffrent tension!?!!
we are very lightweight crew (275 lbs)
what is the best adjustement for this sail?
we ride without the wings : trapezing is funnier.
 Post subject: Leech line?
PostPosted: Tue Sep 13, 2005 9:37 am
Maybe Leech Line?
There would be a thin line up the leech (back edge). This would be tensioned only to take out any flutter between the battens.
PostPosted: Thu Sep 15, 2005 5:31 am
thank you matt
that was the leech line...sorry
the other question that i've got is if a took this sail and I cut it to fit a H18 from 1982.
What will be my gain from my rainbow hue dacron sail from 82
will the shape of the sail will be different and affect us?
Charles
 Post subject: Sail
PostPosted: Thu Sep 15, 2005 9:23 am
The 18 sail would be about 1 1/2 feet shorter. The length of the foot is the same on the SX and 18. You would likely cut the bottom of the sail off. It would require reinforcements at the new foot level.
Would it work? Yes.
Difference? Not sure.
