It is currently Sun Jun 21, 2026 1:10 pm
PostPosted: Fri May 15, 2009 12:36 pm
Tybee I-20s have stainless pins, they break gudgeons and rudders backing up. One of the F18s tore the transom out today. Last Velocity post says Trey as a gudgeon about to break currently, probably a result of the hard start today.
PostPosted: Tue May 26, 2009 7:05 pm
Just a warning; if you DO use fiberglass pins, you MUST tie the rudders onto the boat as a backup. The Chesapeake Bay still holds a set of EPOs and castings and a hot stick after both pins broke on my H16 at speed...
For the same material at the same WEIGHT, a hollow rod will be stiffer than a solid one. It will be a bigger diameter in order to match the solid rod weight, and THAT'S where the extra stiffness comes from.
20's are famous for bending SS pins. I always just rotated the pins and used the rudders to bend 'em back so I could pull 'em out. I figured if the transom was strong enough to bend 'em, it was strong enough to bend 'em twice. :-) I threw the bent ones away; learned the hard way that they don't bend three times without breaking...
