It is currently Fri Jun 19, 2026 3:04 pm
PostPosted: Thu Jun 09, 2011 7:08 pm
You can get any studs you want, or make your own by cutting off an allen. I would discourage using bolts instead of studs as the wings are much easier to install with studs. I have found that I don't want wings on the boat all the time, you may not either. Also a stud saves the threads on your slugs if you try to uni-stall and re-install the wings several times.
2010 AHPC C2 #218
PostPosted: Fri Jun 10, 2011 11:50 pm
I made my own studs from a stainless bolt. Cut the head of the bolt off so you have all threads with the the proper length. Take a hack saw or moto tool and cut across the end of the stud. You just made your own screwdriver slot to turn the stud into the slug. Quick and inexpensive.
1989 Hobie 18 Worlds Boat, Magnum Wings & Spinnaker
1987 Hobie Holder 20 #273
dale.vanlopik"at"att"dot"net
