It is currently Sat Jun 20, 2026 2:57 am
 Post subject: Cam cleat conversion ?
PostPosted: Fri Aug 01, 2008 6:58 am
Has anyone tried to swap the OEM Seaway cam cleats on the Jib and Main blocks with Harken cam cleats? I found the specs on the Harken, but cannot locate any specs for Seaway... primarily hole spacing.
I've measured the Seaway, but not with a caliper, so I cannot be sure it's an exact fit.
I recall many years ago when I had a H16, that to do this, an adapter plate was needed? God I hope that's not the case with the H18.
Thanks for your reply.
Chris
'88 H18SE Arís
PostPosted: Fri Aug 01, 2008 8:20 am
Chris,
The spacing on the Harken cleats is just a little closer than the spacing on the seaway cleats.
I have swapped them out many times without using an adapter plate by using a drill bit, and applying sideways pressure to elongate the holes in the mounting flats on the block.
Takes a few minutes because the stainless material is very hard, but it is really not all that difficult.
The benefit is that it only represents a minimal an investment of time rather than money spent on adapter plates, and there is no additional bulk added to the assembly.
I have never had any problems using this method of adapting the harken cleat to the seaway block.
Stephen
PostPosted: Fri Aug 01, 2008 9:02 am
You don't want to use the adapter plates. Drilling as stated above is a easy fix. I suggest replacing the whole deal with lighter,smaller, better harken blocks.
PostPosted: Fri Aug 01, 2008 9:08 am
Ronstan makes a damn good cleat (just check out a new 16)
It get tired of the springs breaking in the H150's
Sheet In...Max Out
www.fleet297.org
PostPosted: Fri Aug 01, 2008 10:53 am
Thanks for the info on the Harken cleats. There's no way I'd want to use an adapter.
So you say the Harken 150's tend to break their springs? Which Ronstan cleat are you referring to as a replacement?.. and do you know how they fit the Seaway mount?
Since I'm restoring my '88 H18 this season, at present I'll stay with the OEM blocks. Maybe next year I'll upgrade to the Harken blocks. Got a daughter going to college in the Fall of '09!
Chris
'88 H18SE Arís
PostPosted: Fri Aug 01, 2008 11:07 am
Ronstan 5011
38mm is 1.5" spacing
Don't get me wrong HARKEN is excellent product, but my choice on a complete retrofit would be all Harken blocks, except for the cam cleats.
Sheet In...Max Out
www.fleet297.org
PostPosted: Fri Aug 01, 2008 7:40 pm
My youngest just graduated in May......... Hurrahhhhhhhh
I get a raise this year !!!!!!!!!!!!!!!!!!!!!
For the first time in 8 years, I no longer feel your pain !
PostPosted: Tue Mar 29, 2011 5:15 pm
Though this one needed a bump back up. So the cam cleats on a H18 seaway jib block can be swapped out. I have 2 harken jib blocks I want to install could I just use a dremel and cut the seaway blocks off the traveler car and use a small shackle on the Harken blocks?
Floyd
00 Tiger
http://www.HobieFleet33.com
10 Mile Surfside, Texas
Join us on our Facebook group: Surfside Sailing
PostPosted: Tue Mar 29, 2011 9:28 pm
Either that, or a little more expensive opition is to buy these from Murrays
http://www.murrays.com/mm5/merchant.mvc?Screen=PROD&Product_Code=21-0371&Category_Code=C-J&Store_Code=MS
This keeps the seaways good as a back up, or you can sell them
Bruce
78 Hobie 18
#1159
PostPosted: Wed Mar 30, 2011 6:27 am
oh look... my thread has resurfaced!
ncmbm (Mark, Mike?) suggested changing the jib blocks over to a smaller and lighter unit. what has anyone used? part numbers?
I'm still paying for college!
Chris
'88 H18SE Arís
PostPosted: Wed Mar 30, 2011 11:13 am
I just do not want to spend anymore cash or time on this 27 year old boat till I take it out a few times. I think for now I am going to pull the cleats off my spare Harkin blocks and rig the seaway blocks to make them fit like someone mentioned above.
Floyd
00 Tiger
PostPosted: Thu Mar 31, 2011 8:49 pm
I did not get a chance to do this can someone tell me if the old metal cleats will tear up my brand new 5/16 tropthy braid?
Floyd
00 Tiger
