It is currently Fri Jun 19, 2026 9:01 pm
 Post subject: shroud anchor pins
PostPosted: Sun Sep 28, 2008 6:55 am
In replacing my shroud anchor pins, I am having a hard time finding a socket that fits inside the bearing plate. Any suggestions for where to find a very thin socket?
H18 #4549 Catasaurus
PostPosted: Sun Sep 28, 2008 9:05 am
Good on ya for changing those suckers!
I stick a pair of vice Grips up in there. Grease the new ones up with Lanocote or some other grease/anti-seize so they don't gall.
Happy sailing!
Sail Revolution
Join us on our new FB Page!
PostPosted: Sun Sep 28, 2008 5:40 pm
Agreed, use a vice grip to hold the nut. Stick a screwdriver into the hole of the anchor bolt to tighten or use a pair of plyers.
PostPosted: Sun Sep 28, 2008 7:07 pm
srm wrote:
Agreed, use a vice grip to hold the nut. Stick a screwdriver into the hole of the anchor bolt to tighten or use a pair of plyers. sm
When tightening the new anchor pins, just snug is plenty tight enough.
Too tight and you are unnecessarily stressing the fiberglass.
If you leave them even a little bit loose, it stresses the bolt as the mast "walks" back and forth.
Stephen
