It is currently Sat Jun 20, 2026 10:49 pm
 Post subject: Righting pole mount
PostPosted: Sun Mar 28, 2010 10:27 pm
I am in the process of making a righting pole out of an old windsurfer mast. What is the easiest way to mount it? Pictures would be helpful.
Jeff Serene
1984 Hobie 18 Magnum
Phoenix, AZ
 Post subject: Re: Righting pole mount
PostPosted: Mon Mar 29, 2010 3:25 am
Jim here. Google "soloright", they have a system made from an oar which may help.
ADDICTION
1989 HOBIE 18 SE/sx wings
HOBIE ALTER SIGNATURE MODEL
PostPosted: Mon Mar 29, 2010 7:13 am
The one thing I don't like about the Solo Right is that your sticking one end in the dagger well. if you don't have the angle just right, the well can get damaged.
Jeff Serene
Phoenix, AZ
PostPosted: Tue Mar 30, 2010 11:14 am
Here is a righting pole that I installed the end of last year and I have not used it yet. I tried the cheap alternative for mounting on the dolphin striker by using a bicycle goos neck. I hope it hold, but this is only compression forces and should be fine. :) From hearing about another 21SC owner who made his own and then had a few problems. The main change is to thru bolt the cleats and pulleys thru the mast as the rivets with glass will mostl likel pull out. I can' wait to use it. Also, the cost was about $20 for the pulleys, cleats and $8 for the bike gooseneck.
http://www.hobiecat.com/community/viewtopic.php?f=45&t=14627
