It is currently Fri Jun 19, 2026 10:49 pm
PostPosted: Mon Jul 12, 2010 8:50 am
Is there an improved batten clip or devise to keep battens tight without having to check and tighten every time on the main sail?
PostPosted: Mon Jul 12, 2010 11:42 am
Depends on how old the ones you have are. The current cap (black) with a "V" jam holds them tight if routed correctly through the "V". It only holds load in one direction.
PostPosted: Mon Jul 12, 2010 12:13 pm
The trick I've always used is to take the tail of the batten tie line and tuck it behind one of the tensioned lines after setting it in the V-cleat so that the tail is wedged between one of the tensioned lines and the batten cap. This keeps the line locked in the V-cleat.
Another thing you can do is to put an overhand knot (or a series of overhand knots) in the line so that when you set the line in the V-cleat, the knot prevents it from slipping back.
PostPosted: Fri Aug 27, 2010 2:22 pm
thanks, your tip about overhand knots to keep from slipping was golden, sailed 20 more time and battens never loosed up Thanks
