It is currently Sat Jun 20, 2026 8:16 am
 Post subject: Roller furler
PostPosted: Fri Sep 17, 2010 2:37 pm
I bought an 18 last week and am getting it ready to sail. I've never been around a roller furling jib before and am not sure if my roller works, it's not set up on the boat yet. I assume that it would wind itself back up? I can spin it in either direction freely. Is it busted or do I just not know how it works lol.
 Post subject: Re: Roller furler
PostPosted: Fri Sep 17, 2010 3:09 pm
It does not wind itself back up automatically. You uncleat the jib sheets and pull the line coming out of the furler to roll up the sail. You uncleat the furler line and pull the jib sheet to unfurl the sail.
I suggest you download the H18 assembly manual available on this site. It explains how to set up and operate the jib furler.
PostPosted: Fri Sep 17, 2010 3:57 pm
Thanks. I understand now. I downloaded and read the manual but for some reason it didn't make sense until I read after reading the replys.
PostPosted: Sat Sep 18, 2010 7:38 am
you may find that one direction works better than the other i think mine winds up clockwise. (furling in)
eric, sail #205
PostPosted: Sat Sep 18, 2010 1:38 pm
This may help:
[youtube]http://www.youtube.com/watch?v=OhrzlrgVEBk[/youtube]
Sail Revolution
Join us on our new FB Page!
PostPosted: Tue Sep 28, 2010 6:08 pm
To furl jib while under sail you need to hide the jib by bearing off, so that you can furl the jib easily. Do not head up wind. Practice first. Life's little pleasures with the 18.
PostPosted: Tue Sep 28, 2010 7:54 pm
It's also really important to let off the mainsheet. If you're sheeted in tight, the upper swivel probably won't spin which will cause the system to bind.
PostPosted: Wed Sep 29, 2010 9:15 am
The furler most certainly works in one specific way. The line enters on the port side of the drum. If you furl the sail in the wrong direction the line will take a hard right turn when entering which will cut the drum over time.
Detach the clew blocks... Wind the forestay / drum clockwise when looking down on it, but be sure the sail is NOT furled when the line is fully-wound (un-wind the sail). Or... with the drum unwound... detach the clew blocks and wrap the sail around in the same clock-wise direction. Then re-attach the clew blocks.
