It is currently Mon Aug 03, 2026 3:29 pm
PostPosted: Wed May 17, 2006 8:01 am
I have a solid 18 mast on my boat currently. Want to use a Tiger main on it. Can I cut it 1.5' higher and install the comptip to get 29.5'? Is there a difference in standing rigging length and tang placement? Is there a comptip designed for the 18SX. I will be running a spin as well, from a Tiger. Where will the spin tang install? Is the comptip strong enough for the chute? Any and all help appreciated. Found a used SX mast for $250, is that the way to go? Also will I run into boom issues with a Tiger main on a 18?
PostPosted: Wed May 17, 2006 1:21 pm
When I started to look into putting a chute on my H18 I was advised by a number of people to no do this on a comptip. It's too difficult to affix a strong enough tang to handle the load created by the chute. As for the rest, someone else will have to help you there.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Wed May 17, 2006 1:36 pm
The 20 (comp tip mast) had a kite option, why not the SX? I don't know the location/s.
May be best to post on 20 and Tiger forum also. A lot of those guys sailed 18's, before the 20's, before the Tigers.
You may also try/ask Chris Green (aka flumpmaster) he's sailing a Tiger, previously an SX and has spin set up experience on the SX and I believe the 18 as well.
Fleet 297
PostPosted: Wed May 17, 2006 1:50 pm
I have an 18SX, and the standing rigging is a different length than a standard 18. Probably best to order the standing rigging from a Hobie dealer, and when you do emphasize the 18SX length. My boat also has a Hobie manufactured spinnaker, but I've not used it yet. I can't help you with the boom question.
