It is currently Sat Jun 20, 2026 5:24 pm
PostPosted: Fri Apr 22, 2011 7:44 am
What size grommets are in the Hobie tramps and how thick is the foam plug that is in the mast base? Thanks, Bob.
PostPosted: Fri Apr 22, 2011 9:27 am
They're #4 spur grommets.
You can get a kit to do 24 grommets (hole punch, dies, 24 grommets/washers with teeth) at McMaster-Carr http://www.mcmaster.com/#two-piece-grommets/=bzl06z
They aren't quite the same, since you would be installing with a hammer/die instead of the production bench press that Hobie Cat uses.
The foam plug is about 4" thick.
PostPosted: Fri Apr 22, 2011 5:09 pm
How well do you trust a friend to swing a "BIG" Hammer ??????
HarryMurphey
H-18 mag/ #9458
Fleet 54 Div 11
PostPosted: Mon Apr 25, 2011 11:30 pm
That's pretty cool... any reason you could not use the stainless ones... aside from being a bit more expensive? I seem to recall some stainless gromets somewhere on a Hobie of some kind...
