It is currently Sat Jun 20, 2026 5:22 am
PostPosted: Wed Jun 29, 2011 12:03 pm
anyone know offhand if the mast step/base for an H18 will fit the extrusion of a prindle 18 mast ?
thx.
PostPosted: Thu Jun 30, 2011 5:59 am
I don't think so, seems the Prindle extrusion is more round and not teardrop shaped. You might be able to machine it to fit.
PostPosted: Thu Jun 30, 2011 7:20 am
i'll check it out this weekend...
seems the P18 solid alu mast may be a decent option for an all alu H18SX sized mast... I think the P18 is a few inches shorter than the SX mast, but about 9 inches larger than the standard H18.
Of course not sure about shrouds/forestay. Like I said, looking into it.
PostPosted: Thu Jun 30, 2011 8:54 am
If the Prindle mast is 9" longer than an 18SE mast, then it's 9" shorter than an 18SX mast. The 18SX mast is 18" longer than a stock 18 mast IIRC.
PostPosted: Thu Jun 30, 2011 7:47 pm
(broken) p19 mast base, probably a bit different since 18.2 and 19 are different from 16 and 18, but should be similar.
