It is currently Sat Jun 20, 2026 12:26 pm
 Post subject: hull id number
PostPosted: Mon Jun 20, 2011 5:20 am
hi, i got a used hobie yesterday that needs fixing up. the hull # is scmh6766m82e.can some one tell me what model it is and where i can oreder parts. thanks,vic
 Post subject: Re: hull id number
PostPosted: Mon Jun 20, 2011 12:35 pm
Likely CCMH?
Hobie 18.
Parts are available from any authorized Hobie dealer:
http://www.hobiecat.com/support/dealers/search/
You can download a parts catalog here: http://static.hobiecat.com/digital_assets/hobie-sailing-parts-spring2011.pdf
or request a printed one: http://www.hobiecat.com/support/catalog-request/
 Post subject: shroud length
PostPosted: Mon Jun 20, 2011 2:18 pm
thanks.i need new shrouds.the current ones measure 20'7.5".is that the standard part #? thanks again.
PostPosted: Mon Jun 20, 2011 3:35 pm
20' 5" pin to pin (pin hole, outer edge / load bearing surface).
Standard shroud will be fine.
#60792001 Black Shroud
