It is currently Sat Jun 20, 2026 2:46 pm
PostPosted: Sat Jun 18, 2011 5:40 pm
Do I have to take my crossbar end casting off to get the slugs into the tramp channel?
PostPosted: Sat Jun 18, 2011 7:32 pm
yes...
well I did anyway... just a few rivets... can do.
onlhy need to remove from 1 side, however... :-)
PostPosted: Sun Jun 19, 2011 6:08 pm
The correct answer is no.
The wing slugs will fit in the slot where you insert the tramp, The tramp has to come off, insert the slug or slugs, put the tramp on. If you want to sail with the wings off, leave the slugs in place.
1987 Hobie Holder 20 #273
dale.vanlopik"at"att"dot"net
PostPosted: Sun Jun 19, 2011 6:37 pm
Mine went on just like DVL said....Jay
PostPosted: Mon Jun 20, 2011 4:35 am
There must be different diameter slugs cause there was no way the ones I had were gonna fit in the tramp slot openeing....
I bought (4) wing "anchor" plates (the type that rivet to the crossbars). I know if I install the aft starboard plate I will not be able to remove the tramp without drilling the rivets. I was thinking about using long through bolts and bolting the plate to the cross bar so it can be easily rem,oved. Opinions? I figures this will not compromise strength since I'd also be drilling 4 holes in the crossbat if I were to rivet it on....
PostPosted: Thu Jul 07, 2011 9:24 am
Instructions I have say pre-84 boats require enlarging of the slot, so no, probably not different sized.
PostPosted: Fri Jul 08, 2011 7:57 am
I think you may need to add some inner support so you don't pul the bar together. A tube like the mast has at the rotator arm bolt.
PostPosted: Fri Jul 08, 2011 11:53 am
I've got magnum wings and one of the nuts that secure them to the crossbar was missing when we pulled it out of the water last week. Does anyone know what size that nut is offhand?
The ox is slow but the earth is patient
PostPosted: Sat Jul 09, 2011 9:21 am
I think its a 5/16 coarse
2010 AHPC C2 #218
PostPosted: Sat Jul 09, 2011 8:19 pm
5/16 diameter 18 threads per inch. (course)
Use a 1/4 diameter -20 threads per inch bolt, washers, and nuts to connect the wings to the tabs, (instead of a pin). It keeps everything tighter.
