It is currently Mon Aug 03, 2026 8:48 pm
PostPosted: Tue Aug 23, 2011 10:24 am
Hi Experts! I need to know if it is OK to add a 5" (curved) inspection port centered between the daggerboard trunk and rear crossbar. I found postings stating it's OK behind the rear crossbar, but nothing mentioning in front of it.
Mark
PostPosted: Tue Aug 23, 2011 10:26 am
Just that you would be sitting on it at times. That can crack the port or the surrounding area due to the hole.
PostPosted: Tue Aug 23, 2011 10:35 am
Excellent, thanks!
PostPosted: Wed Aug 24, 2011 8:12 pm
There also is a big foam block in that area, so you aren't going to get much room to look around in there.
1992 Hobie Cat 18 #16943
