It is currently Sat Jun 20, 2026 5:39 am
 Post subject: Shroud anchor pin nuts
PostPosted: Fri Feb 24, 2012 10:58 am
To go with new shroud anchor pins, I'm going to replace the nuts that go with the pins. The parts diagram in the back of the catalog lists the nut as part 8050321, but the list of parts in the back doesn't have any part with that number. Does anyone know what these nuts are supposed to be?
Steve
1990 Hobie 18SX #2077
PostPosted: Fri Feb 24, 2012 11:19 am
That old part number is no longer used (we need to update that in the parts guide) It was a heavy duty nut - we just use normal nylock nuts - its a 5/16" x 18 thread pitch
Part number 8050331
Jacques Bernier
http://www.hobie.com/
PostPosted: Fri Feb 24, 2012 11:29 am
Part number 8050331
Thanks. What's the difference between 8050311 "NUT 5/16-18 NYLOCK STD" and 8050331 "NUT 5/16-18 HX NYLOCK-LP"? I'm assuming the "LP" is "low profile", but whats the "HX"?
PostPosted: Fri Feb 24, 2012 11:48 am
When part numbers are put into the system someone enters them - and the descriptions vary over the years - I know LP is low pro - but I can't seem to figure out the difference otherwise.
PostPosted: Fri Feb 24, 2012 2:19 pm
Part number 8050331
Yes, please update the parts guide. Having the wrong part number for that nut cost my dealer two pins and nuts when he followed the guide last year and sold me the wrong ones (the nuts seized on the new pins which then had to be broken off to remove). Through trial and error we found #8050311 works. For those who aren't aware, it's the same nut used to secure the rudder blade to the rudder casting.
