It is currently Mon Aug 03, 2026 3:05 pm
 Post subject: Trapeze Rigging
PostPosted: Mon Aug 06, 2007 9:22 pm
Does anyone have a diagram on how to properly rig my trapeze lines?
Hobie 18 - 3169
star light, star bright... starboard is on the right
PostPosted: Tue Aug 07, 2007 7:56 am
what trap system are you using and do you run wings?
PostPosted: Wed Aug 08, 2007 5:47 am
I'm trying to set up just the standard adjustable trapeze rigging, and I do not have wings.
Hobie 18 - 3169
PostPosted: Wed Aug 08, 2007 7:48 am
Its pretty simple. Tie one end to the bungee, install the jamb(which has 2 loops around it), go thru the eye on the trapwire and tie off on the trap handle or dogbone. The bungee holds the handle or dogbone tight to the trapwire eye. The jamb limits how low you trap. So, bungee on one end and handle on other. Jamb goes between trapwire eye and bungee tie off point, closer to tie off than handle. Hope this helps. If you have adjustable traps these instructions are not correct.
