It is currently Mon Aug 03, 2026 11:26 am
 Post subject: Dolphin Striker removal
PostPosted: Mon Jul 28, 2014 11:50 am
I've been hammering/blastering my dolphin striker on my 18 for hours and i'm not having any luck… Hoping for some suggestions. Thanks
PostPosted: Mon Jul 28, 2014 12:13 pm
On the striker rod ends in the corner casting? They get fused and are not likely removable easily. If that is the issue here... for replacement of the striker post and casting? Use an automotive scissor jack to force the rod down to set the post casting.
PostPosted: Mon Jul 28, 2014 5:49 pm
If the striker rod is frozen to the end castings, the only option besides liquid wrench and hammering that I can think of is to drill out the rivets holding the mast step to the front crossbar (two rivets on the old style, four rivets on the new style mast step). This will allow you to lift out the mast step and dolphin striker post. The striker rod will still be in the end castings, but with the post removed, you may be able to knock one of the end casting out of the crossbar. If you can get one of the end castings out of the crossbar, then you should be able to put a pair of vice grips on the striker rod and spin the end casting to break the rod free from the casting. I know I did this once, but I don't recall if both end castings were frozen or if it was just one. With the striker post removed, you may also be able to break the rod free by tightening the nuts on the end. Anything that allows movement between the rod and the casting will help get it apart.
Obviously, the last resort, if you really need to get the thing apart, would be to cut the striker rod and pull the end castings out. Then replace the striker rod.
PostPosted: Mon Jul 28, 2014 6:24 pm
How about some pictures?
You might also tell us why you want to remove the post and more detailed step you have taken so far. Oil, Heat, Hammer.....
Corkguy H18's a many
Corkguy H18, Tiger, Wildcat
