It is currently Mon Aug 03, 2026 6:37 am
PostPosted: Tue Dec 02, 2014 9:46 am
I have a customer who is having difficulty locking his new Hobie 18 Main sail halyard ring. He is experienced and seems to understand all the tricks. I am also confirming with our loft as to the current specification, but what do you guys think? His new grommet is larger and the center is 1/4" further aft than his old sails. Seems we may have made a change and that seems like a good thing to hold the head in place. He just can't seem to hook the ring.
PostPosted: Tue Dec 02, 2014 2:06 pm
will check my dimensions and post the results, hopefully by tomorrow.
later
2015 H16, with spin,
PostPosted: Tue Dec 02, 2014 3:31 pm
I have experienced the same thing. I use an Aussie style halyard ring now and it works well. It is easier to lock in my old sails.
Tom
Fleet 259, Central Coast CA
H18 ('81)
H18 ('85)
H20 ('97)
H18 ('78)
PostPosted: Tue Dec 02, 2014 4:42 pm
Our loft confirms the dimension is correct at 1 3/4"
Seems better technique is his answer.
PostPosted: Fri Dec 05, 2014 10:34 pm
I have a new Hobie main sail with a manufacture date of April 2013 and haven't had any more difficulty hooking it than older sails while using the same halyard/ring setup.
PostPosted: Sat Dec 06, 2014 5:05 pm
Pictures sent to Matt...
PostPosted: Sun Dec 07, 2014 8:29 am
My clever wife reminded me that we used to have a terrible time hooking up the original 1989 Mylar SX18 sails....
and they were very old sails, well used, and had been repaired more than once,
which was one of the reasons we upgraded to new sails.
New sails go up and hook up like a dream.
PostPosted: Wed Mar 16, 2022 5:41 am
Just to revive an old post.
Apparently the same headboard is being sold. I went to replace my 85 mainsail headboard and then realized that not only are the rivet holes in the wrong position but the main shackle hole is a good deal farther back from the luff track. Probably far enough that the ring would be held off the hook. I now see why some people have to put their boat on it’s side to hook the main but have no problem releasing the hook.
The old gromets are 1/8, the new plate 3/16. I could drill the sail out but the alternate locations would Swiss cheese it up pretty good and some holes would overlap the old ones half way. Would be ghetto
So I’m back cutting my own out of aluminum plate stock like I should of to begin with. I knew something would be off.
