It is currently Mon Aug 03, 2026 11:00 am
 Post subject: Hul ID numbers
PostPosted: Sun Jun 19, 2016 6:46 pm
I have just begun the restoration of an 1981 H18 that has been sitting on the hill for 15 or so years. I am curious about the Hull number meanings.
My HID is CCMH5170M81H-R
I have worked out everything except the -R.
I realize this is not critical but I am curious.
Thank you all in advance for any help.
 Post subject: Re: Hul ID numbers
PostPosted: Tue Jun 21, 2016 6:37 am
You're right, looks like you've got an 81, the -R or -S stands for port or starboard. The other hull should be marked CCMH5170M81H-S
Mike
'78 H18 (unnamed) sail #14921
'08 H16 sail #114312
'97 H21SC sail #238
PostPosted: Tue Jun 21, 2016 9:17 am
Umm, no.
The "-R" means "Replacement". At some time or another, that hull was replaced. When a replacement hull is ordered, Hobie Cat engraves the original hull number and the "-R".
"-S" means "Second", as in a boat with a slight defect.
PostPosted: Tue Jun 21, 2016 1:14 pm
Oh? Well that's odd. So you're telling me that I have a replacement port hull and a starboard hull with a slight defect? What sort of defect would result in a hull designation of -S?
Would the hulls otherwise be marked with the exact same HIN?
I haven't noticed any defects with that hull, other than a soft spot I found that turned out to have poor resin saturation on the inner layer (in the deck, just aft of the rear crossbar). When I drilled & filled the soft spot, the epoxy soaked right through the dry/porous glass layer and made a mess of the inside of that hull, which I didn't realize until I went to put in a hull port a year or two later.
PostPosted: Tue Jun 21, 2016 1:21 pm
Cosmetic defects generally like a minor issue with the gelcoat or graphics, things of that nature. A lot of times it's stuff you wouldn't even notice.
PostPosted: Tue Jun 21, 2016 2:14 pm
Yes, the hulls would have the same HIN (other than the -R)
The defect may have been on the hull that was replaced. Like srm said, it's probably something you'd have to look very closely to find. Sometimes the gel coat doesn't separate cleanly from the non-skid pattern or there's a ding that had to be repaired. The "S" designation only shows up in the high-production years of the early '80s, when Hobie Cat was cranking out boats by the tens of thousands per year.
PostPosted: Wed Jun 22, 2016 5:11 pm
Thank you all for the information.
Now to figure out the rigging and what needs to be replaced.
:D
