It is currently Mon Aug 03, 2026 11:00 am
PostPosted: Mon Aug 01, 2016 8:12 pm
I had to replace the starboard lower casting, that was befor learning they are different?
I have no clue if I got a starboard casting or not. The manual says there is a red or green dot, but there's no dots.
Also, how do you tell the rudders apart, do they bow?
Forrest
PostPosted: Tue Aug 02, 2016 8:46 am
Figured out how to differentiate the upper castings byblookingvatvtje curve on the arms, curving inward is how they are supposed to be, I gather that the lower castings are the same but I haven't figured out the rudders yet
PostPosted: Tue Aug 02, 2016 9:10 am
There is no difference between Port & Starboard lower rudder castings or rudder blades. Only the upper castings are "handed".
There is a difference between the "Old Style" and "New Style" rudder system for the H18. Around 1987, the entire rudder system for the H18 was revamped which included changing the upper and lower rudder castings. The old style and new style rudder castings are not interchangeable (i.e., you can not use an old upper casting with a new lower casting or vice versa).
The old style lower castings had an aluminum "latch" that engaged a rolling pin on the upper casting when the rudders were locked down. The new style lower castings have a rotating plastic "cam" that engages an adjustable plate in the upper casting when the rudders are locked down.
Probably the easiest way to tell the two systems apart is by looking at the the upper casting. If you see a recessed slot in the top of the upper casting with the head of a hex bolt showing (5/16" bolt), then you have the new system (this is the rake adjustment for the rudders). If there is no hex bolt in the upper casting, then you have the old style system (no rake adjustment). It can be hard to tell the two systems apart by looking at the lower castings as they look very similar.
PostPosted: Tue Aug 02, 2016 12:45 pm
i've got the old style with 2000 tiger rudder blades
PostPosted: Tue Aug 02, 2016 1:45 pm
That is really odd. Never heard of a tiger blade on a Hobie 18.
Old style castings would have a metal spring loaded cam.
PostPosted: Wed Aug 03, 2016 8:56 am
Shoot my bad, a 2000 18SX, not a tiger
PostPosted: Wed Aug 03, 2016 9:45 am
2000 would have the newer castings too.
PostPosted: Thu Aug 04, 2016 9:21 am
I only got the blades from the 2000.
PostPosted: Thu Aug 04, 2016 9:37 am
Ahhh.
PostPosted: Mon Aug 15, 2016 12:35 pm
Hobie dealer drilled them for me, work awesome
