It is currently Mon Aug 03, 2026 7:37 am
 Post subject: Wind Indicator
PostPosted: Fri Aug 24, 2018 4:51 pm
Any recommendations for a wind indicator for the Hobie 18? I used to sail with a buddy that had a Hobie 16 and he had the Telo Cat Wind Vane that was great but it does not appear this will work.
 Post subject: Re: Wind Indicator
PostPosted: Sat Aug 25, 2018 4:54 am
Telocat works well and can be installed on a Hobie 18. You just need to buy the adapter to allow it to be installed on the furler drum.
I also recommend drilling a small hole at the top of the arm of the Telocat so you can install a cotter pin/split ring. This will keep the unit from accidentally dropping out of the retaining bracket and getting lost.
PostPosted: Sat Aug 25, 2018 7:01 am
Thank you srm. Is the adapter you are referring to the Hobie furler adapter CM7705?
PostPosted: Sat Aug 25, 2018 8:56 am
Now that I have added a spinnaker, I had to remove my beloved Telocat, with split ring.
This has resulted in a large debate:
Which is better? 4 track tape or 8 track tape....
We attach about 8" to each bridle wire.
2015 H16, with spin,
PostPosted: Sat Aug 25, 2018 12:01 pm
That looks like the one.
