It is currently Mon Aug 03, 2026 8:47 am
PostPosted: Wed Dec 26, 2018 8:16 pm
Hi all,
My comp tip looks like it's had a hard life. I'm hoping the damage is just in the surface layer.
I think my best bet will be to grind it down to the glass in all the damaged areas to see what is happening.
That looks like grinding away a good bit of the coating!
If the core is sound, I can put a new coating of either vinylester or epoxy on it.
Any thoughts on what's going on here, and what I should expect? Just replace it?
https://mega.nz/#!3WwDAajQ!nfhVGD-wGgyJt7AMQ0RzqB9PrLwkw-fHkAfiIGt70v8
https://mega.nz/#!3T5RBQgT!VxxBok1pqesVM2giyAX3BBdRM5v6w-owk7PKjENEXkQ
https://mega.nz/#!qWoRkKyB!ki2lVGsHtyeC096ro04km6HUsftXbp9zbW_n_gawyYI
https://mega.nz/#!eepFxKxI!OrZtIf1SdW0REco43j2P3OnaWcxU0WahVi0r-0rOZNY
https://mega.nz/#!rLxRCQ4J!BdA2oBSsrQaC7s_VcOewwsbWqGQXkjl9PILMvFCo2gs
Thanks!
PostPosted: Thu Dec 27, 2018 7:22 am
Sorry - I can't figure out how to get the pictures to embed...
Another thing I could try would be to just clean the comp tip really well, and then fill the cracks and chips with very low viscosity epoxy, and hope that is adequate.
I could connect my shop vac to the mast tip and put it under a bit of vacuum to help draw the epoxy in anywhere the crack is more than superficial.
Certainly cheaper and easier....
PostPosted: Fri Dec 28, 2018 5:30 am
I’d just sand it back by hand and paint it in 2pak clear paint, same paint as on your car. That’s assuming the cracks we can see are not structural amd only cosmetic.
John Forbes
Hobie 18 Reimagined
Sail # 490
Boat name: 18@heart
http://www.hobie18.fun
https://www.facebook.com/Hobie18catamaran/
