It is currently Mon Aug 03, 2026 9:11 am
 Post subject: Installing new Gooseneck
PostPosted: Wed Jul 18, 2007 11:04 am
I have a Hobie 18 from the early 80's and slowly the parts are all wearing out. I am currently trying to replace the gooseneck in the boom but have no clue as to how to properly install the new part. Any help would be appreciated.
PostPosted: Wed Jul 18, 2007 12:50 pm
I would guess you are asking about the pin that extends from the boom and attaches it to the mast. If so you must remove the rivets, the cap and then there is a c clip on the end of the pin that must be removed. Install new pin, clip and rivets.
PostPosted: Thu Jul 19, 2007 4:32 pm
Usually what is broken is the roll pin or the casting. Or the casting is wore out. Easy to fix, just $$.
1989 Hobie 18 Worlds Boat, Magnum Wings & Spinnaker
1987 Hobie Holder 20 #273
dale.vanlopik"at"att"dot"net
PostPosted: Sun Jul 22, 2007 2:51 pm
A cheap fix, you the end casting is the problem. it's often the hole in the end casting that gets worn out and enlarged. The other end casting is the same part without the hole. ;-)
Damon Linkous
1992 Hobie 18
www.MemphisGuru.com
www.Catsailor.com
www.TheBeachcats.com
