It is currently Mon Aug 03, 2026 4:20 pm
 Post subject: Help with ID & serial #
PostPosted: Wed Jan 09, 2008 5:45 pm
I just picked up what I believe is an 18' Hobie. I found a serial # on the right transom that reads: 9XLA13710(or G)3(or 9)79. It runs vertically from top to bottom. The only other id I can find on the boat are a couple of stickers from the early 80's saying it was part of a Hobie fleet in Sandy Hook NJ. Any help would be appreciated.
Thanks Al
PostPosted: Wed Jan 09, 2008 6:01 pm
Yeah, I've got those same kinda numbers on my right hand transom on my H18. I think that they are factory placed serial numbers. They may not be in that area on every hobie 18 because I think they changed actual manufacturers in the early 80's. just my 2cents which is down to one now :D
Wes
92 Miracle 20 + magnum wings
PostPosted: Wed Jan 09, 2008 8:02 pm
All serial numbers begin with CCM.
There's an article in the FAQ that explains the format.
PostPosted: Wed Jan 09, 2008 8:09 pm
Almost all, if not all, HID #'s ( Hull ID Numbers) on Hobie 18's start out with the letters CCMC which I believe stood for Coast Catamaran Manufacturing Company. Followed by a series of numbers and letters that can be decoded to give you some additional information about the boat.
In some cases there were some additional letters to denote special circumstances regarding that particular boat. possibly a factory second.
There are others on this forum that can guide you to the exact and accurate information you may be looking for.
Based on what I personally know, it sounds like the boat you have bought is either NOT a Hobie product, or has been re-serial numbered by an entinty other than Hobie Cat.
But, I could be wrong, it HAS happened before.
Stephen
Hobie 18
PostPosted: Thu Jan 10, 2008 4:45 am
CCMC
CCM - Coast Catamaran
C - model designation (C=Hobie 18.)
Read the FAQ here:http://www.hobiecat.com/community/viewtopic.php?t=1155
PostPosted: Thu Jan 10, 2008 6:19 am
Thanks for all the suggestions :D If it is not a Hobie, any idea who made it :?:
Thanks Al
PostPosted: Thu Jan 10, 2008 6:51 am
This is the link you want - http://www.uscgboating.org/recalls/mic_database.htm
PostPosted: Thu Jan 10, 2008 7:14 am
MBounds wrote:
That was very helpful :D
Thanks Al
