It is currently Mon Aug 17, 2026 7:25 pm
 Post subject: Pedal Squeaks
PostPosted: Fri Aug 05, 2016 4:53 pm
The right pedal of one of my Hobie Eclipses originally had a squeak on the right side pedal, but it gradually went away with use; however, at this time I also noticed that the bolt for it began to back out. I tightened it (along with the other ones), but the squeak has returned. Is there any way to lubricate the pedal hinges? Do I need to remove the bolt and spray lubricant inside or can I just try coating the hinges externally?
Thanks for any help.
 Post subject: Re: Pedal Squeaks
PostPosted: Sun Aug 07, 2016 9:45 pm
My peddles weren't squeaky when new, but very stiff. A generous dose of WD-40 loosened them up. Still no squeaks!
Enjoy!
Wil Thoms
Newport Beach
Hobie 16 with Tequila Sunrise sails (in the past)
Hobie Revo 11 for peddle, paddle, fishing and sailing
Hobie Eclipse 10.5 Solar Yellow
SurfTech 12' Touring SUP
PostPosted: Mon Aug 08, 2016 1:27 am
I did have a squeak in my outback mirage drive pedals and I used Inox spray on them and also on the cables. Inox (or a lanolin lube) I find is a better lubricant than WD40, as WD40 will wash away any grease etc that is already there. Inox has fixed the squeak in my mirage drive. WD40 may be ok for a quick fix.
PostPosted: Mon Aug 15, 2016 9:28 pm
I sprayed some lithium grease in/around the hinging peddle... last time out, no squeaks. :)
Thanks.
