It is currently Fri Jul 03, 2026 11:30 pm
PostPosted: Tue Jun 15, 2021 6:05 am
(Hobie people read these, right?)
There is a small foam piece on the back of the pedals that the boards "rest" on, actually they come to a stop on this foam.
It has come off (it was glued).
1. I am surprised for the amount paid for the duro, that a piece has fallen off.
2. Obviously, I need to glue it back on
3. what glue should be used?
The dealer I bought this from is 2 hours away, a trip to them is not possible
PostPosted: Mon Jun 21, 2021 12:52 pm
Contact cement. Brush on the pad and pedal... let dry to tacky and then press on.
PostPosted: Wed Jun 23, 2021 5:14 am
Thanks. I called the dealer and they said to use a 3M adhesive for plastics (forgot the exact name). I bought similar and have had to reapply now three times. Each time I have to scrape off the older adhesive and add new.
So, I have to make sure the pad does not fall out when in use and it comes off (yesterday), Clean it up, reapply and let sit to cure.
PostPosted: Wed Jun 23, 2021 8:33 am
Contact cement is the best solution.
