It is currently Mon Jul 27, 2026 1:07 pm
 Post subject: Eclipse caliper handles
PostPosted: Thu Jun 09, 2022 5:19 am
Hi All,
I bought new 2 x Eclipse Dura 12 some 4 weeks ago.
After 1 week one caliper broke, 2 more days another caliper broke and now after 2 weeks more all 4 caliper handles are broken.
Is that a common issue with the Eclipse?
Are there stronger caliper handles to buy?
Thank you
Ziv from Israel
PostPosted: Thu Jun 09, 2022 2:32 pm
Ziv,
If they Flip the boards the calipers could be impacted if hitting the ground or beach. If they squeeze both at the same time they can overstress them.
These are the likely causes.
Contact your dealer or European distributor to get the parts you need. There is no stronger caliper needed.
PostPosted: Tue Jul 05, 2022 7:25 am
mmiller wrote:
Ziv,
Is this under warranty?
Local dealer never heard of this issue (??) and doesn't have any spare parts.
What can we do?
Ziv
PostPosted: Thu Jul 07, 2022 11:25 am
Ziv,
This is not covered by the Warranty. It is miss-use. I can't assist you from the US. Parts would be sourced through Hobie Europe or Hobie Kayak Europe. Whoever your dealer works through. I believe it is HCE.
PostPosted: Thu Jul 07, 2022 11:53 pm
Matt,
Since the stepper was delivered to my client in it's box and I didn't rig it, could he have rigged it wrong in a way that cause the calipers to brake?
8 calipers broken in 6 weeks and it's miss-use?
Is this the first time this issue is brought up?
Thank you
PostPosted: Fri Jul 08, 2022 8:47 am
Ziv,
My first comment is the explanation. If both are pulled at the same time you can pull hard enough to fail the caliper. Multiple caliper failures is an indication that they do not understand how to use the product. Likely they pull hard on both thinking that will stop the Eclipse from moving forward.
PostPosted: Sun Jul 10, 2022 4:51 pm
My one and only time on an Eclipse I so wanted pulling both handles to be brakes as I headed too fast into the side of a dock. I didn't pull hard enough to break the handles I but could see how that might happen.
Peter
2016 Hobie Oasis with Evolve v2 rudder mount, Sidekick ama kit, Mirage sail kit, Garmin echoMAP CHIRP 42dv, bilge pump
2007 Hobie Outfitter x 2 with Mirage sail kits, large rudder blades
PostPosted: Thu Jul 14, 2022 6:00 am
mmiller wrote:
Ziv,
If this is the natural instinct to do, pull them both together...than maybe it should have been considered in the engineering.
It is highly unreasonable that in a product that costs an arm and a leg, 10 calipers will break in 4 weeks time and it's not even on warranty.
PostPosted: Thu Jul 14, 2022 8:36 am
Ziv,
As noted in my first response... contact your dealer and regional distributor for help.
PostPosted: Mon Jul 21, 2025 5:06 am
It sounds like a fairly common issue based on the posts here. Just curious if anything might be in the works for future models.
Ask ChatGPT
