It is currently Thu Aug 20, 2026 3:45 pm
PostPosted: Thu Mar 21, 2019 6:30 pm
Does anyone have a side imaging fish finder on the Compass? Do the left and ride side of the bottom hull interfere with the signal at all?
It appears in videos/pictures that the left/ride side of the bottom hull are slightly lower than the 2019 Outback but I'm not sure since I just have a Compass.
I'm looking into getting a Hummingbird Helix SI finder and using the BerleyPro mount.
PostPosted: Mon Apr 01, 2019 1:15 pm
I'm in the process of Installing a Lowrance HDS touch gen2 I was given. I'm installing the structure scan transducer on a RAM arm. This unit requires 2 transducers and I'll put the smaller one in the lowrance pod and the structure scan on an arm. Looking forward to trying it out.
PostPosted: Sat Apr 06, 2019 2:20 am
If you mean to put the transducer in the transducer Lowrance ready hole, it won't work...
François - French Hobie fishing team - Outback 2019 papaya
ex: Revo 13 2007 - PA 14 2008 - PA 12 2009 - Outback 2011/2013/2015 - Compass 2017
PostPosted: Wed Apr 10, 2019 1:41 pm
I installed the Lowrance Gen 2 7 touch and it works perfectly using the structure scan transducer on a ram arm. The smaller transducer installed into the Hobie Lowrance pocket perfectly. I don't need the structure scan when fishing the flats, so it's nice to be able to remove it when I don't need it.
PostPosted: Sat Apr 20, 2019 2:01 am
I also looking forward to this, previously I took to the shop and mounted for them, really looking forward to how to do it myself perfectly :)
PostPosted: Sun Apr 21, 2019 5:26 pm
I have mounted the a triple shot under the compass and it works great.No issues at all.
PostPosted: Tue Apr 23, 2019 7:02 am
Max, did you buy a different transducer 'cover' plate (with modified 'bulge')?
Or are you using the Compass factory transducer cover?
PostPosted: Mon Apr 29, 2019 11:03 am
The Lowrance Tripleshot units are the easiest to install using Hobie parts. Here's the plate you need:
72020220
MOUNT KIT, TRIPLESHOT
BerleyPro has transducer mounts that adapt right over the Lowrance Ready cavities on Hobie kayaks for all other brands.
Howie Strech
Parts & Accessories Product Manager
PostPosted: Wed May 08, 2019 11:47 am
Hstrech, does that cover (protect) entire transducer, or does transducer stick out the back?
I'm looking at an hds7 carbon, but I've never used side scan before. I do a fair bit of dragging of my hull, though and am worried about anything lower than existing factory transducerducer cover
