It is currently Thu Aug 20, 2026 9:41 am
PostPosted: Fri Aug 20, 2021 6:11 pm
The riveted foot on my loader just dropped off. Does anyone have a fix?
PostPosted: Tue Aug 24, 2021 7:26 am
so here's what I did. I used a couple of short 3/8 well nuts and put it back on. We'll see if it holds.
PostPosted: Tue Aug 24, 2021 4:41 pm
We also changed the rivets to a split type / bulb type.
https://www.hobie.com/parts-and-accessories/?ItemGroup%5Bquery%5D=bulb
PostPosted: Wed Aug 25, 2021 11:03 am
The rivets on mine popped out if I looked at them the wrong way, replaced them with the new style, Will try them this weekend but they seem to be holding much tighter than the old ones did
PostPosted: Tue Aug 31, 2021 9:33 am
Well, that didn't work. Popped the first time loading. Guess I'll just use this till it falls apart completely then buy a new one. Maybe by then, Hobie will have figured out something that works for a part that is absolutely necessary. bummer.
PostPosted: Tue Aug 31, 2021 1:47 pm
PostPosted: Tue Aug 31, 2021 3:46 pm
Tried it out two times this last weekend after replacing all the original rivets with the new style and no issues for the first time :P
PostPosted: Thu Feb 03, 2022 12:14 am
The rivet on my Compass loader broke the first time I used it, and the weight of the kayak came down on the rudder. I thought the rudder broke, but it was ok. I think the likelihood of damage to the rudder is lower without the loader.
PostPosted: Thu Feb 03, 2022 12:27 am
Thr rivet popped out of my Compass loader the first time I used it and the kayak almost broke the rudder. It seems safer fot the rudder to not use the loader.
PostPosted: Mon Feb 07, 2022 11:01 pm
Mine popped out too, it’s unfortunate that they sell it that way but since I replaced the rivets with the new type I’ve used it 20 times and it’s still perfect and I don’t baby it.
They really should fix them before selling them, almost useless as they come
PostPosted: Tue Feb 08, 2022 10:10 am
We had replaced all of the rivets for stock on hand and changed what the vendor uses when building them some time ago. This should not be a recurring problem.
PostPosted: Thu Feb 10, 2022 11:03 am
I took the loader back to the Hobie dealer and they repaired it using the correct rivet. I used it once so far and it held up. Hobie is lucky to have a great dealer in Hawaii; Stan is awesome.
PostPosted: Fri Feb 25, 2022 9:28 am
I don't think a rivet is a long term solution here. What I did was drill a hole on the opposite side of the rivet ,large enough to get a large washer inside the loader. Placed a stainless screw and a nut with washers and this has held up very well .
PostPosted: Fri Feb 25, 2022 9:43 am
It is a special kind of rivet that is like a molly screw for drywall. Works very well. No washers are required.
PostPosted: Mon Feb 28, 2022 2:54 pm
I can testify that it’s been a non issue since I replaced the original rivets with the new type, and I don’t baby it.
They do the job
