It is currently Thu Aug 20, 2026 12:33 pm
PostPosted: Thu Mar 03, 2022 1:28 pm
What are the 2 screws for on the right side of the inside of the kayak, in front of the tiller lift string.
PostPosted: Wed Mar 09, 2022 8:21 am
They are an integral part of the tiller/rudder lifting and lowering system. Don't mess with them.
PostPosted: Wed Apr 06, 2022 11:06 am
Have this same question. Kevinsta, have you figured this out yet?
PostPosted: Thu Apr 07, 2022 8:05 am
There is a turning block on the inside... as noted... leave them be.
PostPosted: Sat Sep 10, 2022 1:27 pm
Is there a parts diagram for this turning block? The aft screw on my Compass is not mounted to anything - it slides right out. I don't know if it's supposed to thread into the pulley assembly, or if it passes through and is secured with a nut.
PostPosted: Sun Sep 18, 2022 5:47 am
After relocating the round hatch to the bow, I gained sufficient access to what's behind those two screws. If feels like plastic and has recesses for nuts. I failed to find the missing nut, and now have a substitute installed and both screws are snugged down.
I'm disappointed that there's no supporting documentation readily available for these detail parts & assemblies.
