It is currently Thu Apr 23, 2026 12:24 am
PostPosted: Fri Mar 30, 2012 2:03 pm
Just bought an '83 H16 that 'needs work.' Just forward of the forward crossbar there are two circular openings about 5" in diameter each. There is a housing for each opening but the circular screw type plate is missing. Contacted west marine for a replacement but they said they only came in 4/6/8 diameter so I'm at a loss.
Anyone have any experience with these plates and where to get replacement parts, seeing as mine are an atypical size?
I suppose in a pinch I could just buy the 6" plates and use some marine caulk/sealant but it would look pretty sloppy.
Thanks!
LP
PostPosted: Fri Mar 30, 2012 2:45 pm
Any Hobie dealer can get you 5" ports (part #V1093 (white) or V1100 (black)). You have to buy the flange and the port cover together. They're about $12 each set.
PostPosted: Fri Mar 30, 2012 2:51 pm
Great! Thanks, appreciate that. One less item on my Hobie themed scavenger hunt.
LP
