It is currently Sun Jun 21, 2026 1:28 am
 Post subject: Question.....
PostPosted: Mon May 21, 2012 5:18 pm
Is the rod that links both rudders suppossed to be bent in the middle ? Mine has a slight bent right in the middle were the tiller pivot is.
Every second that passes cannot be recovered, so make good use of every one of them that you have left.
 Post subject: Re: Question.....
PostPosted: Mon May 21, 2012 6:25 pm
No. It's supposed to be straight.
Not uncommon for it to be bent, though. As long as it's not too severe, it's not a big deal as long as the rudders are aligned properly (a bend makes it shorter, so the rudders will be further apart at the trailing edges).
PostPosted: Mon May 21, 2012 8:52 pm
Thanks Mbounds. I`ll try to fix it.
