It is currently Sun Aug 02, 2026 10:11 pm
PostPosted: Mon Jul 31, 2006 6:38 am
I was going over my hulls and one hull is a bit softer that the other. One is solid with no give and the other when you push down with your thumb has the slightest give. A few milimeters at most in an area the size of my hand. It's right in front of the front pylon so I'm afraid it is the start of a soft spot. How soft does it need to be before a repair is needed? Should I address it now while it is small and easier to fix? Thanks
 Post subject: Small Delamination
PostPosted: Mon Jul 31, 2006 4:21 pm
It may be difficult to get resin in the small area. It also may be an area that is simply crushed a bit. I suppose it is woth a shot if you can get it stopped now.
