It is currently Mon Aug 03, 2026 1:55 am
PostPosted: Thu Oct 02, 2014 7:33 am
A friend has a newer 16. (2002) mint... Every time we sail the creaking noise drives me nuts. (us nuts). With each shift in the wind and each movement we make on the tramp, each of the 4 pylons creak loud. I'd mentioned he may need to?
1. tighten the bolts? they likely are tight
2. turn upside down and fill with epoxy - (I know many do this for stiffness) but seems extreme
3. try to get some lube inside the frame where the pylons go in?
4. put some nylon material/washers between pylon and bolt?
ANYONE know why or have a easy solution? I've sailed dozens of 16s and never experienced this before. Frame seems rigid. when we pull the boat in and out I don't see flex in the hulls which I have seen on old boats (that didn't creak).
PostPosted: Thu Oct 02, 2014 8:25 am
Minute movement between the crossbars and hull surface is the most likely culprit, I would think. If you loosened the attachment bolts and squirted a little silicone or wax lube in there you might find things would quieten down.
On the other hand, I applied this same idea to another boat I have and the grunting and groaning actually got worse.
PostPosted: Thu Oct 02, 2014 8:38 am
My guess would be that it may actually be the side bars moving in the corner castings and not the crossbars/pylons. The side bars are a looser fit in the castings and when you sail, if you sit on the tramp, you can actually feel them moving around. At least that was the case on the 14 I sailed at this year's NAC - it had some creaking going on and I could feel the side bars move when it made noise. Maybe coat them in silicone caulk before installing.
PostPosted: Thu Oct 02, 2014 9:17 am
PostPosted: Thu Oct 02, 2014 2:45 pm
We'll try to narrow it down next time out - and see if we can verify it's the side bars. Thanks for the suggestion.
PostPosted: Fri Oct 03, 2014 1:19 pm
Skip the caulk.
From Christensen's, "Welcome To A Fleet", circa 1978. Mine's buried somewhere in the den.
Use your choice of aluminum beverage can. As I remember, we used Old Style. Cut and fold pieces and cram them between the castings and rails and beams. Use a screwdriver and a hammer and drive them in to make them tight, then tighten the tramp.
Makes for a tight boat.
PostPosted: Fri Oct 03, 2014 2:57 pm
As mentioned above, the side rails are probably the main culprit.
I was very disappointed when my relatively new 2004 Hobie 16 creaked louder than the 1971 boat I owned for 30 years. Roughly two years ago, Matt Miller posted that the factory had been chamfering the sharp edges of the side rails to prevent creaks on new boats.
I decided to give it a try by filing down the sharp edges of the side rails and sprayed some Boeshield B9 in the corner castings for good measure. The result was a dramatically quieter boat -- well worth the effort.
PostPosted: Mon Oct 06, 2014 2:52 pm
I have a 2008 H16 that is creaking as well. My previous 1985 was very quiet with minimal creaking. I would be interested to understand what actually takes away the creaking.
Jake C
2008 Hobie 16
PostPosted: Mon Oct 06, 2014 3:21 pm
It has to do with the interaction of the sidebar in the casting, so lubrication or seating in something like 3M 5200 will quiet it.
This became an issue when we started using french castings... hardness of the anodize maybe.
PostPosted: Mon Oct 06, 2014 4:10 pm
Any suggestions on how to seat it without actually taking boat apart?
PostPosted: Mon Oct 06, 2014 4:50 pm
Inject?
PostPosted: Mon Oct 06, 2014 5:08 pm
mmiller wrote:
Inject?
Can you elaborate?
PostPosted: Mon Oct 06, 2014 5:20 pm
I would suggest taking it apart... the only other option would be to inject sealant in the gaps to stabilize the bar under load. Dampen the sound?
No proven advise here.
PostPosted: Sun Jun 28, 2015 7:02 am
Is the tramp tight. It should be tight enough that the side bars bow in a tad. If not it will cause a creeking.
