It is currently Sun Aug 02, 2026 4:31 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Apr 12, 2007 9:37 am
Thx Matt. Good advice.
P.S. I wouldve bought the Hobie jib traveller upgrade but the illustration in the catalog seemed incomplete (to me)concerning the apparent absence of actual cleating for the jib sheet
PostPosted: Thu Apr 12, 2007 7:41 pm
tim wrote:
Thx..straight back or criss cross 'em?
PostPosted: Fri Apr 13, 2007 12:08 pm
Thx Hobie 1616..
and I suspect that is a great setup. I got my answer from Matt (criss cross) as I had the older riveted-on track style jib set up that utilized the old all-in one metal jaws floppy/spring loaded jib sheet/cleat traveler cars..(without the 2 swivel cam cleats mounted between the mast and track)
I have now upgraded using the same set up but uses a newer Ronstat combo camcleat traveler for jib sheeting and the newly mounted swivel cam cleats(between mast and track) to handle the traveler control duties.
Like the previous photos posted from James? Now that you are thoroughly bored.. :wink:
Tim
H16 '80
So Ore
PostPosted: Fri Apr 13, 2007 8:58 pm
I used that setup on two boats for 20 years. Other than replacing the bungee that pulled the cars to the center every year, it was bullet proof.
