It is currently Thu May 21, 2026 12:38 pm
 Post subject: Holey Mast Step
PostPosted: Mon Oct 20, 2025 7:55 am
I just got an '81 H-16 and am shaking it down to get it into shape for this spring. After taking off the mast, I was perplexed to see that the striker post goes THROUGH the mast step and INTO the mast base casting.
A little research online indicates that the post threads into the mast step (makes perfect sense). What is happening here?! Advice appreciated!
Jon
 Post subject: Re: Holey Mast Step
PostPosted: Tue Oct 21, 2025 12:42 pm
Online
This shows the cross section of a mast step. There are only a few threads connecting the dolphin striker post to the mast step. The striker should not be able to slide thru the mast step.
If the threads of the striker are still good, then you need to replace your mast step. Push your striker post up some thru the front cross beam enough so that you can thread it into the bottom of your new mast step until they are flush with the bottom of the bowl (where your teflon chip goes). It is easier to do this before you rivet your new mast step to the front cross beam.
In this picture's case, the salt water caused the threads of the striker and mast step to fuse together over time on my 82H16 and this was the only way to separate them.
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
PostPosted: Thu May 21, 2026 6:24 am
Great photo, thank you!
Users browsing this forum: Tim H16 and 2 guests
