It is currently Mon Aug 03, 2026 12:47 am
PostPosted: Sat Jul 14, 2007 1:46 pm
I just ordered an arriba fx3 stick and the cork ball grip accessory. It showed up with the rubber 6" handle on the end of the stick, andf the ball grip is in a plastic bag with a tube of epoxy, but no directions. The arriba site was of no help.
Whats the sets way of gettign the rubber grip off without damaging the stick? and do I just coat the inside of the cork ball with epoxy and stick it on? (I was wondering if the epoxy was to coat the outside of the ball to make it last longer.) Feels like a stupid question, but I'd appreciate any help you have. I used to always just use the stock fiberglass stick with a duct tape wrap at the end. Now that I'm an old man, figured I'd upgrade.
Raced extensively as a kid (against Matt Bounds!!), just bought a 20 year old 16 and am refurbishing it.
Sail # 21888
PostPosted: Sat Jul 14, 2007 6:37 pm
You might be able to work the rubber grip off by twisting it. If not, use a safety knife and slit it up one side and peel off.
The epoxe is used to glue the cork ball on. Mix it and apply liberally on the inside of the ball. Push on and twist a full turn to coat the surface of the stick. Wipe off any that pushes out and set aside to set.
PostPosted: Sun Jul 15, 2007 2:28 pm
Somewhat unrelated, but you all reminded me of a good trick. Aqua-spray, or any hair spray for that matter, makes a great adhesive for grips and such. Its still breakable with a little working, but not to the extent of glue or epoxy. Thought I'd throw it out there.
PostPosted: Mon Jul 16, 2007 6:01 pm
Thanks. The rubber grip came off just fine, and cork ball went on smoothly
Sail # 21888
