It is currently Sun Aug 02, 2026 12:48 am
PostPosted: Thu Sep 23, 2004 5:56 am
Hey there - I can load shock cord into 1/2" hollowbraid to make my own righting lines and save some cash, but I was wondering how to terminate the ends so that the end of the hollowbraid and the end of the shock cord don't ever separate. Any ideas?
Thanks!
G
 Post subject: Termination
PostPosted: Thu Sep 23, 2004 8:20 am
3/8 Shock Cord fits into 1/2" hollow braid. At the end of the area where the shock cork will be (not the full length of the 1/2" line) bring the shock cord through the jacket and all the way aropund the outside of the line and back to itself again. Use hog rings to fasten.
PostPosted: Thu Sep 23, 2004 8:41 am
Thanks Matt!
G
 Post subject: what are hog rings?
PostPosted: Thu Sep 23, 2004 12:06 pm
what are hog rings? where do you tie this shock cord/rope?
PostPosted: Thu Sep 23, 2004 3:31 pm
Hog Rings (and the pliers used to crimp them):
Typically, the line is attached to the rear deck lip, either by drilling a small hole through the lip (where it won't leak) and using a small diameter line to attach the hollow braid, or alternatively, you can loop the small diameter line around the rudder pin between the deck and the lower rudder casting.
