It is currently Mon Aug 03, 2026 3:44 pm
 Post subject: Rivit size
PostPosted: Wed Jul 15, 2009 12:37 pm
Matt M. what size rivit(or screw) is used to hold the sheave block for the jib travellor in the front corner casting?Also is there suppose to be a bushing inside the sheave block?
 Post subject: Re: Rivit size
PostPosted: Wed Jul 15, 2009 4:42 pm
No bushing... Rivet is 8011251 according to the catalog. That is a RIVET 6-16 PH HD-ALUM (RIVET 3/16 x 1-1/8 PH-AL)
PostPosted: Wed Jul 15, 2009 5:42 pm
thank you :)
PostPosted: Mon Nov 30, 2009 12:45 am
Can you please explain how to translate 6-16 into 3/16 x1-1/8 ?
Thanks.
PostPosted: Mon Nov 30, 2009 2:26 pm
I believe it relates to 1/32 of an inch, so (6) 6/32 = 3/16" Diameter and (16) 16/32 = 1/2" Grip length.
PostPosted: Mon Nov 30, 2009 6:17 pm
Thanks.
PostPosted: Fri Dec 04, 2009 4:34 pm
first number is diameter in 32nds of an inch
second number is length in 16ths
Must make sense to somebody, but I always had to stop and figure
