It is currently Mon Aug 03, 2026 11:56 am
 Post subject: hobie 16 sails
PostPosted: Thu Feb 25, 2010 2:58 am
hi everyone,
just wanderin is there any chance in the near future of hobie using mylar sails for there hobie 16s?
thanks
ramble on
 Post subject: Re: hobie 16 sails
PostPosted: Thu Feb 25, 2010 9:44 am
We have been there, done that. Hobie 16 is the strongest one-design Hobie class and every effort is made to keep it that way. Mylar sails were added in the late 80s - early 90s in an effort to add more color excitement, but the cut / shape was adjusted to try and keep the sails as similar as possible. It just wasn't worth it... we stuck with Dacron for one-design issues.
PostPosted: Thu Feb 25, 2010 11:59 am
Not to mention, that for some reason, the Dacron sails were faster.
Also, the material Hobie used (same as on the 17 - one side Mylar / one side Dacron taffeta) did not hold up well - especially the jib where it hits the mast. Lots of delamination problems.
PostPosted: Tue Mar 02, 2010 4:25 am
ok
thanks alot guys just thinkin about it because i thought mylar sails would add extra performance but i guess not
PostPosted: Fri Mar 05, 2010 11:16 am
If you're not racing, or are racing but have extra dough for a second set of sails, consider an after market pentex sail. You don't get the variety of colors as dacron, but the performance is there.
PostPosted: Tue Mar 16, 2010 6:10 am
I don't know why you would want Mylar on a 16 anyway, The Hobie Dacron Sail will last for just about forever if you look after it and will last for 20 years if you don't, there practically indestructible.
http://beachcatsaustralia.ning.com/
