It is currently Mon Aug 03, 2026 11:47 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Mon May 18, 2009 1:59 pm
Once the nuts are off can the striker simply be pulled out or does the rod that points down from under the mast need to be removed first?
PostPosted: Tue May 19, 2009 6:59 pm
Roy wrote:
Yes take the striker off, there is a nut on each end of the rod, count the # of turns needed to remove the nut. That will take any twisting force off the castings. When you put it together just turn each nut on the same # of turns you needed to remove them.
Bad advice. You can loosen the nuts if you want, but you can't take the rod off (at least without bending it) without removing the castings from the front crossbar.
I've never heard about Hammond's advice (soaking in Coke), but it makes sense. Phosphoric acid (the acid in Coke) is used to etch aluminum prior to painting / epoxy.
Why do you want to take the front crossbar off anyway?
PostPosted: Wed May 20, 2009 10:36 pm
The only reason I thought about taking it off was to facilitate removing the front crossbar on my boat which I have not gotten to move even a fraction of an inch. I have been able to remove the rear one and I was thinking that removing the dolphin striker might help remove some tension that might be contributing to the stuck cross bar.
PostPosted: Thu May 21, 2009 4:47 am
The dolphin striker - tight or loose - has no effect on whether you can get the tramp frame off the boat. Especially since you already have the rest of the frame off.
There's really no reason to take the front crossbar off unless you're painting the hulls and need the hulls separate to fit into a paint booth or something like that. Since it's stuck so badly, you're likely to break something by trying to remove it.
I have owned 16s for over ten years and never had the need to take them apart. I'm on my sixth 16 now (first one was a 1973 - bought new).
PostPosted: Thu May 21, 2009 7:25 am
They will come apart.
Unless the casting or cross bar is bad you shouldn't need to.
You just need a "Perky" :wink:
Pat Bisesi
Fleet 204 Syracuse, NY
PostPosted: Thu May 21, 2009 11:26 am
Rather than beating the heck out of it, try a little heat. Not too much, just a little, with a torch. I've only met one boat I couldn't get apart. Had to bust out the sawzall.
Sail Revolution
Join us on our new FB Page!
