It is currently Sat Aug 01, 2026 4:22 pm
 Post subject: Cut off top of tip?
PostPosted: Fri Mar 30, 2007 10:36 am
If it matches the original CompTip... I can't see whay not.
PostPosted: Fri Mar 30, 2007 10:43 am
There is no issue with the class rules, since essentially what you are creating is the original Comptip installation (with the joint 4"+ above the tang).
PostPosted: Fri Mar 30, 2007 10:50 am
Ok, that will make this fix quite a bit easier :D
Thanks for the help everyone. Now where is my hacksaw??? :lol:
It's such a fine line between stupid and clever.
86 H16
PostPosted: Sat Apr 07, 2007 10:41 am
Well I cut the comptip 4 inches without a problem. I had to take off the halyard holder and come to find out there is a back plate on it located in the tip. Since its fiberglass I'm sure thats why its there so the rivits dont pull through the glass. Anyway I was able to take a screwdriver and take out a bit of the foam core enought to slide it to the proper position and then got the halyard holder rivited back in place. I wasnt expecting to have to do that.
I need to replace the little bit of foam that I had to take out. Does anyone know something that will work good for that. Its not very much but I think it should be filled to maintain the inside consitancy of the comp tip.
The string will be cut. I attached it to the back plate in case I needed to remove it if it didn't fit right.
After that I just need to put the cap back on.
86 H16
