It is currently Sun Aug 02, 2026 6:52 pm
Post new topic Reply to topic  [ 95 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
PostPosted: Fri Jun 01, 2018 6:49 pm
Rat rod trailer worked! First mast stepping.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Fri Jun 01, 2018 9:03 pm
TexKat wrote:
Suggestion for tramp hiking straps. Buy grommet kit, install grommets through the existing stitched on pieces. Then string 3'8 to 1'2" line through them and thread line through foam hvac insulation tubing for feet to slide under and be comfy. Have used this system for years. Works well, every few years replace the foam tubing over line. Tape the ends of tubing to prevent tearing. Looks nice too when done properly.
By the way...beautiful end result on your $50 buck Hobie!
I would love to see a picture. Help me understand the 3’8 to 1’2”.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Sat Jun 02, 2018 3:05 am
I think it was meant to refer to the line diameter: 3/8” to 1/2”.
PostPosted: Sat Jun 02, 2018 5:49 am
Yes. That helps.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Sat Jun 02, 2018 5:51 am
It’s pretty windy. I’m nervous even raising the sails.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Sat Jun 02, 2018 7:41 am
I got over it. Nothing left to do but go sailing. I’m not a pro a trimming sails. I have wrinkles.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Sat Jun 02, 2018 9:45 am
Looks good. Adjust the downhaul to get the wrinkles out. With the mainsheet blocks attached to the traveler car, bring the mainsheet up to the mast. Pull down on the downhaul sheet and then pull on the main sheet the boom should inch down a little at a time and then cleat the down haul and you're done.
Great job by the way, it's awesome to see the progress you have made in restoring your Hobie Cat, cant believe it was in a field when you found it and look at her now!
Marty
Lake Martin, 'Bama.
PostPosted: Sat Jun 02, 2018 12:44 pm
Well I guess I’m an official HC16 captain. Snapped the rudder fix after about 40 minuets. I’m guessing 8 to 10 knot wind. Water was on verge of producing white caps. Did a few closed hauls and a few beam reaches then snap. Went mostly running back to dock with one rudder and upper casting port dragging in the water. 50 Cent will now rest on lift so I can build the shore station. I will get a new/old rudder and get back to it. I’ll need a new trampoline too.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Sat Jun 02, 2018 1:44 pm
So windy and only one rudder.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Sat Jun 02, 2018 3:24 pm
Love it! 50 dollar Hobie on the lift under cover, 40k ish (wild guess) power boat out in the open! You sir have your priorities straight.
#hobielife
Side note: ever since you started this thread I have been offering everyone on c-list 50 bucks for their hobies and sunfishes and I have had no takers...
PostPosted: Sat Jun 02, 2018 4:26 pm
#hobielife
HaHa. That’s a 96 MasterCraft. It’s the kind nobody wants anymore. Closed bow and center engine. 10K at best...maybe 12. Everyone wants surf boats these days. I guess I buy the things that most don’t want.
I just got lucky on this HC. I’m sure some, maybe a lot would not agree. She is a project....and my “getting it sail ready” cost is creeping up. And now I need a rudder, tramp, main Halyard line and jib sheet line. After that, I’ll be content and have super fun on this thing.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Sat Jun 02, 2018 9:02 pm
FiftyDollar wrote:
Yes. That helps.
Yes line size may vary for what you may have on hand.
UK Wildcats have 8 now!
1976 H16 27640
1985 H16 89112
PostPosted: Sat Jun 02, 2018 9:18 pm
1976 H16 27640
1985 H16 89112
PostPosted: Sun Jun 03, 2018 5:05 am
Cool. Thanks. I’m pretty sure I’ll need to invest in a new trampoline. This one is thin.
FiftyDollar
73 HC16 “50 Cent”
PostPosted: Sun Jun 03, 2018 5:12 am
Thanks for everyone’s responses and listening to my story. I really appreciate the help along the way. I probably should have done this a long time ago. I’ll slow down on my posts but will update as things progress or come up.
Gone sailing.
FiftyDollar
73 HC16 “50 Cent”
